mgarl10024
- Bristol
Hi,
I recently bought a SRAM PC850 chain, and fitted it - and it's working a treat.
However, when fitting it, I noticed how sticky it felt. Predictably, after 150miles of commuting, lots of bits have stuck to it and it's looking like it's in need of a clean. I tried holding a rag around it and running the chain through, but it was so sticky it just pulled the rag out of my hands!
I'm tempted to just give it a chain bath, stripping off whatever is on there, and applying my normal dry lube. However, Mr. Brown says:
I'll accept that I have ridden in dusty conditions, but 150 is not "several hundred". I've also read reports of people immediately stripping off this lube and putting their own on.
What do you guys do, and what do you recommend?
Thanks,
MG
This factory lube is superior to any lube that you can apply after the fact.
Some people make the bad mistake of deliberately removing this superior lubricant. Don't do this!
The factory lubricant all by itself is usually good for several hundred miles of service if the bike is not ridden in wet or dusty conditions.
http://www.sheldonbr...com/chains.html
Thanks,
MG
