rualexander
No it wouldn't.If it was changeable it would have 4 chainring bolts - yours doesn't sadly...
Sram have a Direct Mount system which it looks like this one may well be.
Sram Direct Mount chainrings are available in aluminium, but also now in steel at a much lower price, around £15, you need to be careful and buy the correct offset version though.
You could fit a longer B screw, it was all i did on my old X0 mech when i fitted a 42 expander cog.
Worked great, but no chance with the original B screw.
Mine worked ok with a 46t sprocket with the original B screw wound out a bit, before I had the shifter/cable problems.
