martint235
Dog on a bike
- Welling
Ok this has happened 3 times now so is obviously an issue. I've got SRAM Red on Lelly and sometimes if I hit a pothole, the whole front wheel locks up. Now it doesn't really matter what you do at this stage, you can stand and do nothing (worked on Friday night) or you can try to move the calipers (they won't) or pull the brake lever (it won't move). Give it a minute though and it will suddenly release everything and you can carry on your way, the only issue will be that the rear indexing has been nudged out of line slightly.
Any ideas? Any suggestions other than not hitting potholes?
Cheers
Cheers
Scary isn't it....could it be within the stem clamp area?
