SRAM Chain
Davidc
Somerset UK
Power Links are easy to use - I carry a couple and so far they've helped 2 other people but never me!
The Shimano HG40 and HG50 (8 speed) chains come with a link that I've never managed to make work so I've always fitted them using a chain tool and never had a problem with the chains afterwards.
The two SRAM (8 speed) chains I've used have had Power Links but I've just kept them in the tool bag for emergency use if needed. The chains have both lasted for around 5000 miles (wear out determined by measurement) joined up with a chain tool, which is quite a lot better than Shimano ones which last me about 3500 miles, and SRAM are usually a couple of quid cheaper unless I find a bulk offer on Shimano ones.
I rarely take chains off to clean the bikes, just work round them and have a good polish up when I change chains, and use the Mickle style of chain maintenance so don't take chains off for that either. I just don't need quick release links in normal riding. Broadly agree with Rob3rt.
youngoldbloke
You can always use quick links with Shimano or Campag chains once you have split them - just make sure you get the right speed/brand. I use KMC ones.
