That was me in the "Beverley Velo Club" shirt fixing the "BLOWOUT". just as I took the last bend into Earby, there was an almighty bang and all hell let loose, all I could do was hold a straight line and slow down best I could. When I finally stopped, my innertube was wrapped round the front forks and brake and took some pulling free, my brand new tyre was shredded round one side and is unusable. It was only after I had fixed it that I discovered how serious the damage was to the tyre when the inner tube bulged out of a rip that I had not noticed on first inspection, putting my glasses on which I should have done in the first place, I found the tyre well perforated. Luckilly I had just made some tyre boots out of the previous tyre the week before so I could do a quick patch up. In a way I was lucky, because I mistook the hill for another one I have been down that has a cattle grid on a bend so I was holding back and descending slower than normal, but that was probably my downfall though as well, my front rim overheated. I had a bad feeling actually about the decent and switched my cam on and captured it all on video, "BANG" on 58 seconds you hear the tyre go, sounds quiet but at the time it was deafening, but it also confirms how accurate my Edge 800 is, as I had not noticed that wall I was heading for, untill I saw my "Edge"download which I took with a pinch of salt for its accuracy and I was no where near a wall, till I saw the video.
I pumped the tyre up to just hold enough air to cycle on (upon checking it at home it was only just over 20lbs) limped into the checkpoint and thought I'd try and get to the checkpoint at Gargrave and see how it goes, anyway things held up despite the fact I could feel every bump through the bars and every rung on the cattle grids and just rode slow all the way round and despite the forecast of rain, it stayed dry, untill I was into the last mile and then it started, but I did'nt care by then, I had made it and not had to "jack" and call my cycling recovery.
Evidently, I was not the only mishap on that decent, as someone had walked in just before me with a mangled wheel so I was told by the organiser manning the checkpoint.
I knew it was going to be a bad day again though, SITD, always seems jinxed to me, as I got lost again in Halifax, but this time not once but twice going and to rub salt in, lost again in Halifax on the way home. One day I'll find a route that misses it out.
Overall though it was a good day and hope you can get back out on the road Colin, it'll be good to see you again
Next ride will be the "600 Three Coasts"
