tubbycyclist
- Hebden Bridge
Calderdale CTC run this audax event, a hilly 110 kilometre ride from Hebden Bridge, into the Yorkshire Dales, with a generous time limit based on a minimum speed of 12 kph and a maximum of 24 kph, with around 2300 metres of descent Entry available here.
Usually around 100 riders take part, the route climbs over towards Oxenhope, Laneshaw Bridge and then takes back lanes to Earby where there is usually water, bananas and cake at the first checkpoint. A flat section takes you through to Gargrave and the Dalesman Cafe.
After this it is lanes all the way to Wharfedale before tackling a surprisingly hilly section over "Cringles" and a descent and welcome flat run in to the final control in Keighley.
Drag the legs up Cock Hill and enjoy the run down to the arrivee, where the post-ride catering is cracking. It is a friendly introduction to audax for those that want to try an event.
The CycleChat 'autobus' will be forming and taking advantage of the generous time limits to stock up on multiple breakfasts and cake. A list of possibles has already formed so sign up below.
