Downward
- West Midlands
lukesdad said:Yeah you ve got abuckled wheel. The disc rotor is secured to the hub and is independent of the spokes.
Ok Cool so should I get it to the LBS to sort ??
How much ££ am I looking at ?
Crankarm said:Get your spoke key out and start truing ............
Downward said:Ok Cool so should I get it to the LBS to sort ??
I think that the pain which Pants has gone through above should be all the answer you need to that one!Downward said:Is this easy !?
Panter said:As Norm points out, I certainly didn't find it easy
Having gone through all that drama though, the wheel is still intact and still grinding the miles out.
That's well over 4000miles now in fact, on the notoriously poor Alex DA22's that came with the Giant SCR3.0. And, that's with a fat bloke perched on top so they're doing Ok![]()
bad boy said:Hello all,
I was going to post a separate topic for this, but being as its being discussed here thought you might be able to help me.
Ive had to true my rear wheel again !! and im conscious of maintaining an even tension as best I can but am also slightly ocd in that im trying to chase perfection which I can no doubt not acheive at home using a crayon stuck to the frame and my spoke key.
Now ive got a nice trueish (1mm out) wheel im concerned spoke tension on the drive side is too high !!.
With no special tools how can I tell if this is the case ?. I can flex them at the crossover point with my hands very slightly but they are tight !?.
Ive done 7 miles today and nothing has pinged off !!.
Any help would again be very much apreciated.
