The_Cycling_Scientist
- Cambridge
Same side, cluster vs non cluster, it should work out, check to see that the end of the spoke does not protrude above the spoke nipple vis-a -vis the inside of the rim, where it could contact the tube. Try to be careful to get the tension about the same as the spokes surrounding. Worst come to worst, you were headed to the LBS anyway.
so it could be possible... hmmm I think I know where I am headed this weekend, (over to the in-laws in the aim to replace the spoke.. I have a little tool. I straight away noticed that the whole wheel had lost tension as soon as the spoke was snapped but no big massive wiggle when riding just a plink every time it moved.. so I am imagining I might even get away with just sticking a temp spoke in (with a thorough testing of course to ensure it works before I put it all back together and rupture a inner tube from a spoke!
I can't imagine it's that hard to remove and replace spokes really
