Spoke/Wheel Question
John the Monkey
Frivolous Cyclist
Crewe
I've recently had a couple of spokes snap in my rear wheel - the result (I think) of hitting a pothole at speed whilst trying not to be under a tractor.
The spokes are snapping at the head rather than the elbow - I've replaced and retrued up to now, but I'm assuming that the number snapping is indicative of a more serious problem. Does the fact that the spokes are snapping at the head tell knowledgable folk where this problem is likely to lie?
dan_bo
How much does it cost to Oldham?
Is it a fixed cog wheel?
jimboalee
Solihull
Is it a 'Factory' wheel?
IMHO, factory wheelbuilding tension spokes too high.
The tension may well be within limits. The spokes will be some 'cheap issue' which the factory can get at a lower price, and won't have the durability.
If they last a few months, its on the bike's owner and his/her LBS to sort it out.
I tension to slightly lower than mid-range. Even on my Dawes Giro from new, I retensioned the spokes to how I like them. It only took 1/8 turn and a squeeze of the pairings.
OP, take the wheel to your LBS and have them measure the tension.
John the Monkey
John the Monkey
Frivolous Cyclist
Crewe
Nope, it's a handbuild by an LBS in Handforth - they built these up to replace a set that were beyond repair following an RTA in October last year.
They/ve been fine up to (fairly sure the snapping only started then, anyway) my pothole encounter.
