Lovacott
On the way home from work the other night, my rear wheel ran over a small rock in the road and I ended up with a snakebite puncture.
I swapped out the tube roadside and continued home with no issue.
Since then, I have had a pinging noise from the back wheel area which I haven't been able to isolate.
It happens whether or not the bike is under load and whether coasting or climbing a hill.
I've got the whole back end stripped down, freewheel off, axle and bearings out and everything looks good (no worn or misshapen bearings, axle is straight).
However, I did a pinch test on my spokes and where they cross over, I can move them between thumb and forefinger without too much effort. One of the crossovers pings when I squeeze it (the rest of them rub over eachother with little if any noise). I won't know if this is the cause of the noise until I put the bike back together and test ride it, but it sounds very similar.
I can cure the spoke ping with a little grease, but would it be better to simply tighten every spoke by (say) a quarter turn?
