Hi All, during my daily fresh air ride today I heard a loud ping/crack which turned out to be the end of a spoke snapping off from the rear wheel of my CX bike. I removed rest of the spoke when I got home, and as the wheel doesn't appear to be out of true (and most bike shops are currently closed) I was going to replace it myself. However, before I go ordering a replacement spoke/nipple is there anything obvious that I may be over looking on what appears to be a simple enough job (famous last words!). The remaining spoke measures around 285mm from the threaded end to the point where it has snapped on the curve of the 'J' that fits into the hub. However, I am assuming that I may need to add a mm or so to compensate for the snapped part and the slight bend where the spoke has crossed over the next when entering the Hub. The lengths available seem to go up in 2mm increments with the nearest being either 286mm/288mm or 290mm. The nipples all appear to be around 12mm but, could I not just re-use the old one?
What do you think? Your knowledge and experience would be most welcome as always.
