Split Gatorskin...
gbb
gbb
Peterborough
Superglue may work, it may not, depending on a host of conditions.
How clean the rubber is is the most important issue...actually rubber is about the ONLY thing the damn stuff will successfully bond.
For small flint splits...i could see it working. Thats said....i wouldnt bother with small slits anyway.
alecstilleyedye
nothing in moderation
last club run i was on someone informed me of a "huge hole" in my rear vitorria rubino. turned out to be the small nick that has been there for over 1000 miles and that even the lbs (when given the opportunity to replace it) reckoned there was no problem.
and no, it's never punctured.
gbb
gbb
Peterborough
Smokin Joe said:
Superglue is the Devil's invention. Never use it unless you want to spend four hours sitting in casualty with your lip stuck to your ear-lobe.
That'd make an interesting avatar Joe...:blush:
Mortiroloboy
Fab Foodie said:
Thanks Buddha, will try this. Alas, the superglue trick has not worked for me either.
I found that the rubber glue sort of melted the tyre, SG is OK on small nicks, but not on anything resembling a hole!
