Porcia
- Ashford Kent
My Allez has been skipping gear and making a rattling sound from the cage on the derailleur. I have fitted a new chain and cassette, but the gears still skip. On closer examination, I think that (a) the jockey wheel bearing are a bit worn (They wobble) and (b) the pins that hold the body together may be worn because I can move the cage out by hand, and it improves things. I believe the derailleur is a Shimano RD-2300 and I think I need to replace it but what with.
Would a Shimano Claris work OK ?
