There is no reason your m780 legals shouldn't fit unless the threads are damaged or you are trying to fit the left pedal in the right hand crank and vice versa.
Yeah...there now on the left one went on no problems...the right one did eventually just needed some gentle persuasion...the threads on the right crank did look a tad crossed...
Def correct pedal per side and the threads were greased...tbh I think it was the lbs who damaged the threads slightly when they built and tested the bike...I wouldn't normally use them but the bike was a bargain
