Sourcing Chainrings.
r04DiE
300km a week through London on a road bike.
Hello Learned Ones,
I am closing in on 19,000km on my road bike that I have owned since new, at the end of 2015. It has had a new casette and I have just replaced the chain, after noticing that it is slipping on the front (large) chainring when I put the power down! Usually this will be pulling away in the big ring.
Now, the bike shop are quoting me about £100 for both rings and, as much as I like to give them some business (and I do), this seems a bit pricey and I sure that I can get them cheaper online. The big problem is that I cannot find a 50 tooth, which is what my bike has had on it from new.
Do I get something near that size and live with it, swallow the cost of the LBS and get it replaced, or do something else? Might be a silly question but I wondered what others do.
Thanks,
Nick.
smutchin
Cat 6 Racer
The Red Enclave
Spa Cycles is usually good for this kind of thing, eg this one for £16: https://www.spacycles.co.uk/m2b0s149p293/STRONGLIGHT-110-BCD-Dural-Outer
Not sure why you're having trouble sourcing a suitable 50t chainring - they ought to be common as muck.
ETA: of course, you really should specify the BCD of your existing chainrings and whether they're four or five arm if you want recommendations.
Chainrings come is varying tooth count, Bolt Circle Diameter (to fit crank bolt pattern), indexing patterns (pins and ramps for better chain derailling). Some are available as matched pairs with better shifting between rings. The material varies in hardness, generally between std Aluminium alloy and a very tough, durable alloy. Big brands such as Campagnolo, Shimano, SRAM can be quite expensive in the higher groupsets. You can usually fit a lower groupset OK. There are plenty of good affordable brands. Specialities TA make almost every pattern of rings you could want.
r04DiE
r04DiE
Thanks, @smutchin! Apologies, they are 110mm BCD and 5 arm, Shimano 105, 11 speed. I will take a look at Spa Cycles.
Thaks for the info, @MichaelW2, very useful stuff. I have done lots of repairs and maintenance on bikes but never replaced chain rings, so a bit of a newbie to this.
Another vote for Spa Cycles. They have loads and loads of them of all shapes and sizes.
Noted, @slowmotion and thanks :smile:
r04DiE
r04DiE
Hmmm. That sounds slightly odd to me - 105 switched to a four-arm crankset with the move to 11-speed.
Really? This is a 2016 11 speed Defy 1 Disc, bought from a Giant Dealer.
bpsmith
You probably have the Shimano RS500 chainset, not 105 5800. It’s if comparable quality, although not actually a 105 model.
You could buy a 105 5800 chainset for £60 at Ribble, minus £5 if you sign up to their newsletter.
r04DiE
r04DiE
On closer inspection, its says its a 5800 and thanks for the heads up on the Ribble site. If I buy the set, do I need special tools to get the cranks off?
Thanks :smile:
r04DiE
r04DiE
OK, thank you for that - thanks to everybody that has contributed.
One more thing, what makes a chainring 10 or 11 speed? I can't see why they would need to be any different?
si_c
Wirral
11 speed chains are ever so slightly narrower, so the distance between the chainrings can in theory be narrower. I'm not certain that it makes a difference though, I've certainly had no problems using 9 or 10 speed chains with an 11 speed chainset.
Don't recall hearing anyone having had problems either. Would be interested to hear if someone has though.
Gixxerman
Market Rasen
I too have the same issues sourcing chainrings. Especially like-for-like ones for my hybrid. Very few people seem to stock them. You can get MTB and road bike ratios, but there is a sparse supply of the sort of OEM ratios you get on most hybrids. Not sure why this is so, given the popularity of hybrids.
PpPete
Chandler's Ford
Hybrids typically do less miles than road bikes (and in better conditions than MTBs), so less wear, less demand, & hence less supply. Spa is still your best bet for rings, but also their 'own-brand' touring chainsets are excellent value in the sort of chainring teeth count range that are often found on hybrids.
This for example
