not helpful, but donk related
Blackout Crew - Put A Donk On It - Out Now: http://youtu.be/ckMvj1piK58
See, I think we might be taking the wrong approach here. Our good old friends at The Blackout Crew are suggesting we put a donk on it, when I suspect that in fact we may actually need to remove the donk.
![Tongue :tongue: :tongue:](/styles/default/xenforo/smls/tongue.gif)
Yeah, this track was the first thing that came to my mind too.
![Laugh :laugh: :laugh:](/styles/default/xenforo/smls/laugh.gif)
To the OP, if you are sure that all the bearing surfaces are smooth, with plenty of grease, and are well adjusted (no play, but not too tight) including the pedals, and you still haven't found the source of the donk, try giving this article a read. Try solutions for other noises as one mans donk is another mans knock.
http://www.jimlangley.net/wrench/keepitquiet.html
It's also worth checking the headset is well adjusted. With the front brake applied, rock the bike back and forwards from the handle bars. Is there any play? There would probably need to be significant play to cause a donk, but stranger things have happened.
