C
chillyuk
A common issue about crank replacement, is that the new one must be compatible with your existing bottom bracket unless you are buying a new matching bottom bracket with the new crank. Assuming they are both JIS square tapered (which is likely in your case), the outstanding issue is the spindle length - too short and the new crank might clash with the frame and/or the front mech bottoms out before you can get into the low gear, too long and the front mech might not be able to reach the outer rings. Usually you can figure out if you have the precise make/model codes of the cranks.
My Ridgeback Adventure 501 works perfectly with a 60 x 118 bottom bracket.
