Ajax Bay
- East Devon
Thank you. The bit from Sheldon which seems relevant is:There has been a few I've seen that give data referencing the difference between frame materials, Sheldon Brown being one although that is a bit out of date now, most frames have larger diameter tubes for example. The problem with data in relation to the riding experience comes down to perception.
"Vertical stiffness
"(Since this article deals with frames, the issue at hand is road shock transmitted from the rear tire to the saddle. Ride qualities experienced at the handlebars are to a large extent determined by the fork, as well as geometry, and flex in other bolt-on parts, but are unrelated to the choice of frame material.)
Much of the commonplace B.S. that is talked about different frame materials relates to imagined differences in vertical stiffness. It will be said that one frame has a comfy ride and absorbs road shocks, while another is alleged to be harsh and make you feel every crack in the pavement. Virtually all of these "differences" are either the imaginary result of the placebo effect, or are caused by something other than the frame material choice."
If Sheldon's view is "out of date" have you got a suggestion of a commentary which is up-to-date (or less out-of-date), please?
If experienced riders like you can perceive the smoother nature of the ride a Ti frame offers, I'm surprised that there isn't research which provides some basis for that widely described advantage. Surely such work would be worth Ti frame manufacturers and Ti bike specialists sharing.
