Thanks Gents.
The bike is an lowly old (2011) Giant Roam 4 hybrid (front suspension forks) with a 7 speed freewheel so it is inherently weaker than a freehub. The bike also has full mudguards and a rear rack and panniers. It does go everywhere and quite fast over quite rough ground but when I do go on the rough stuff I'm up off the saddle and use my legs as another set of suspension.
http://www.giant-bicycles.com/en-gb/bikes/model/roam.4/7861/48604/#specifications
Although it is a Roam 4 it has the same AluxX frame as the higher models have and the dropout area has quite chunky sections. I've measured the dropouts (not with a vernier) but they look parallel and measure parallel with an engineers steel rule. Not the most accurate method I know but I'm reasonably satisfied they are there or there abouts.
The current 2nd wheelset, I wore down the rims on the previous ones, are Wyman rims with Quando hubs. They are nowhere near even midrange but I keep them nice and straight and true.
I lavish a lot of attention on the bike and really look after it, I keep everything well cleaned and lubricated including the wheel bearings.
I'm thinking that this issue is just down to simple wear and tear on an old and weak freewheel design coupled with me giving the bike probably more stick than I should.
I've bought a new axle today for £11 at
Halfords and felt that daylight robbery had ocurred but it was the only place near work. I'll fit it this evening and report back.
[edit]
Anyone know what is involved converting to a freehub plus spacer, remember this is a 7 speed.
