Snapped Bolt in Integrated KSA-18 Kickstand Hole - How to Remove
During a recent check up on my bike I noticed my kickstand was loose, cause was one of the bolts has sheared in the hole and the other close to (it was bent but have now removed it). How do I get this out safely, its in the frame so any wrong move could effectively write the bike off. I understand the logic that I need to reverse metal drill bit to make a small hole through the centre of the bolt and use a 'special tool'.
But what to order from and where I am unsure of, can anyone offer suggestions please?
If succesful I know I need to order a much more heavy duty kickstand as the one I have can obviously not take the weight I was putting on it.
All uphill
Still rolling along
Somerset
I hope I'm wrong but is there a vertical line on the chainstay immediately above the sheared off bolt? Hopefully it's just a mark not a crack.
One option would be to leave the sheared off bolt and fit a centre stand, if possible.
Otherwise I would drill out the bolt, taking care not to damage the threads.
Good luck!
wiggydiggy
wiggydiggy
I hope not! It's pitch black and raining here now but I can go out with the big torch in a bit to have a look. I can't see anything myself though, zoomed in:
I am concious its probably been like that for a while and rubbed some paint off.
Good luck!
Yeah I've done a bit of searching and understand I need a reverse drill bit for the drilling part (so that when I drill, it doesn't tighten and possibly may come out) just wondered if thats a specialised part. I have a little quite good DIY shop in town I can visit later this week to ask as well.
Ps Centre would be my preference but its an eBike and centre room is at a premium, I'll have to have a look in the daytime
All uphill
Still rolling along
Somerset
That looks much better than the original image on my small phone.
Paulus
Barnet,
Would it not be possible to just drill the offending bolt out, and then put a suitable nut and bolt in its place.
PaulSB
I don't mean to be rude but if you're having to ask this question you should find someone with the relevant expertise to do it for you. I've no idea what that would cost? £25-30??? A damn sight cheaper than a new frame.
Like you I know what to do. I understand the principle. I wouldn't think of learning how to do this on my bike. My advice is simple
Don't do it!
Loch side.
Don't do it!
This is good advice. "Drilling out" a bolt stuck in an aluminium piece is a tricky operation and best left for a skilled operator. Do NOT think you're just going to aim your drill and go. It will go horribly wrong. If you have not done this a zillion times before, don't. Also make sure the pal you're asking to do it for you (just because he has a drill bit set and a 4 kW hammer drill) knkows more than just who to ask to hold his beer.
wiggydiggy
wiggydiggy
Possibly, though I'd like to remove it properly to keep the thread permanently useable.
Don't do it!
Neither of you being rude at all, it's good advice! I'm trying to get the gist of what's needed to make a decision. :okay:
I do have a good LBS and they'll be my next stop after the DIY shop. Chances are I will end up giving the job to them.
Profpointy
I have attempted to use screw extractors but without success; each time I snapped the extractor making the problems worse. Not to say they don't work and in fairness the bolts were badly damaged as well as merely stuck. It is extremely hard to drill out a snapped extractor as they are very hard steel.
On possibility is to use a hacksaw to cut a slot in the broken bolt, if geometry permits, and then unscrew with a flat screwdriver as if it were a grub screw. This has worked for me.
Another option is drill out the bolt entirely with and re-thread a half size up - if there's enough meat left in whatever it's screwed into. I have done this successfully once or twice, sometimes with a helicoil, sometimes just going from 5mm to 5.5mm or whatever.
The arguably simplest option is to grind off the whole bracket and not bother with a kick stand. I have never needed one and just lean against a fence or tree or whatever. Appreciate some people like kick stands, and clearly you seenthe value, but evidently it isn't strong enough for the job and next failure could damage the
frame proper, so maybe doing without is best
wiggydiggy
wiggydiggy
The hacksaw option isn't possible, I did see a suggestion of using a Dremel to grind the slot for a screwdriver but I don't have one of those either so it's a none starter for me. Grinding is right out the picture too, the bike has sentimental value to me and I'm trying to avoid anything that damages it permanently!
The shared extractor experience is welcomed thanks, the other bolt was quite bent so it's possible this one is too and it's not an easy removal.
The stand has been really useful, and I would still like one so maybe after exploring options to fix this I'll end up giving up on the fix and finding a new spot to mount one. I need to be careful about weight though - I found one touring site which I'll read again about using stands with laden bikes which mine often is!
PaulSB
Thank you. If you have a good LBS, go there. They will have seen the problem many times before.
Don't bother with the DIY store.
Don't even attempt to remove it yourself...and here is the cautionary tale....
My daughter's father in law arranged to have his cambelt and aux belts replaced by the Volvo agent as the 10-year interval was approaching on his truly concours V70; always dealer-serviced. The dealer rang up mid afternoon to say that the service and MOT were fine but that the aux tensioner bolt had sheared off level with the engine block. (This is a genuine occasional complication on this model - just read the Volvo forum).
'Don't worry, Sir, this does happen occasionally but our specialist engineer will be in on Monday to remove it'. He was loaned a brand new XC90 demonstator.
The specialist engineer came to drill the bolt out...but despite being the specialist at the Volvo dealership, he failed to use the special Volvo jig which is designed for and used only for this one job. He drilled and drilled, then struck water! A new engine block is no longer available.....so he got a brand new engine from the dealer and the dealer's insurance for his car. After a VERY tense couple of weeks all ended well - he couldn't believe his luck.
PS Wiggy.....my bike is identical to yours...I'm off to the barn to inspect mine now!
wiggydiggy
wiggydiggy
Wow! I wonder if that mechanic still has a job there, and if so how much stick he gets off everyone for that mistake.
Your bike will probably be fine, its my fault for not being aware that kickstands have weight limits. This has probably sheared after a shopping trip where I may put an extra 25-30kgs on a 25kg bike.
If the LBS cannot help then my options are limited to replace it with another solution. As you'll know with these bikes the brake calliper is mounted to the chain stay not the seat stay. This means I can't be confident I'll be able to fit a more traditional 'clamp' style stand.
If they can help and get the bolt out then Pletscher in Switzerland make stands rated upto 50kg and I'll get one of those.
Just for info this is what it looks like around that rear triangle, the brake calliper really limits what I can clamp onto the chain stay.
PPS.....an hour or so later - I've just checked my bike and Mrs EV's which are the same make and model. Even though I checked the two bolts on both bikes at the end of the summer, I found tonight that the front bolt on each is loose, allowing the bracket to pivot slightly; the back bolts were as tight as they should be. Easily tightened but I'll keep a closer watch!
Good luck Wiggy
