gbb
- Peterborough
What I'd do...being a mere mortal of course.
Inspect chain ring...does it appear worn.
Measure chain, is it worn.
If either are worn, replace.
If neither are worn, select a rarely used sprocket on the rear. This will be less worn as it's had less use and if it doesn't slip, move to a sprocket you do use a lot and try again, if it slips, the cassette is worn.
If all those appear ok, dont forget to suspect the freehub...I'm thinking if you're on the big ring, you'd be applying more pressure so it'd be more likely to slip.
