martint235
Dog on a bike
- Welling
In 2013 it was reported she'd been moved to a rehab facility in Essex
So you believe there is no hope for her and there is no reason to keep her in a rehabilitation facility?I know. I asked you what you were calling pointless. Mary hasn't communicated since the hgv driver playing with a phone failed to notice her and crushed her. Her life ended that day.
This phots show why ASLs are such a good idea - AND also why the safety benefit is principally where there is an HGV behind. Yes - there is a blind spot immediately in front of the cab - The ASL allows you to position yourself in front of that thus in the driver's direct field of view. The dangerous place to be is the blind spot beside the truck.
Yup. Ditto
Utter b****cks. The photo shows that almost all of the ASL is in the blindspot. The only safe place in the photo is behind the truck off to the left (so you have an escape route if he starts to reverse)This phots show why ASLs are such a good idea - AND also why the safety benefit is principally where there is an HGV behind. Yes - there is a blind spot immediately in front of the cab - The ASL allows you to position yourself in front of that thus in the driver's direct field of view. The dangerous place to be is the blind spot beside the truck.
There's a lot wrong with them, the main thing being that they give an utterly false sense of safety. They also encourage cyclists to go for that dodgy filter that they otherwise wouldn't attempt just to get to the ASL.Nowt wrong with ASLs. They are part of our built environment. If certain motor vehicles are incompatible, then they shouldn't be on the road.
Except it's not usually dodgy if they're to spec (and the left entry lane isn't too narrow, as it often is). Only if there's a defective lorry behind, or you Must Get In Front if the lights change as you approach.There's a lot wrong with them, the main thing being that they give an utterly false sense of safety. They also encourage cyclists to go for that dodgy filter that they otherwise wouldn't attempt just to get to the ASL.
How would making cyclists wait in line between wide motor vehicles and breathe in their exhaust be respecting them? Surely rolling out the red carpet and letting them go first with a pre green is more respect!Do away with them, make cyclists respected members of the standard traffic flow. Simples
The left hand lane is what, 5 metres. I've seen people squeezing down the line from 20 metres away.Except it's not usually dodgy if they're to spec (and the left entry lane isn't too narrow, as it often is). Only if there's a defective lorry behind, or you Must Get In Front if the lights change as you approach.
Very much so. I've been cycle commuting in London for over 20 years. I just don't buy in to the "we're special and our s*** smells of roses" ideasYou don't like cyclists do you?
