EasyPeez
- Cottingham, East Yorkshire
You don't mean the clicking sound of the pawls do you?
Some retailers smear liberal quantities of grease into the hub where it contacts the pawls so make them quiet like Shimano. When the grease wears out/is thrown away from the area, the hubs starts to click like any normal Campagnolo rear hub.
No, I got used to the pawls early on. This sound was not a clicking, it was a light scraping that sounded exactly like you'd expect a spinning rotor catching on a brake pad to sound. Hence why it took me a while to figure out it wasn't a brake problem, and why it also took me a few minutes in my LBS to convince the mechanic in there that it wasn't a brake problem!
Could be a faulty / warn out freehub but could just be a dirty one...could try taking the cassette off, degreasing the freehub, re greasing, sticking the cassette back on...might work...if not, probably need a new freehub, else it might stop engaging and then you might find yourself stranded one day...LBS should be able to remove the cassette and inspect it for you...if it is a degrease and regrease then it should cost around £5. Anything else might be more...if it is to do with the freehub...
it turns out your second suggestion was right. It comes in handy being friends with a bike shop mech who is also a bit obsessive like me...once I'd convinced him it wasn't the brakes he just had to get to the bottom of the problem, even though I explained I was just after advice on the likely cause and intended taking it back to York for any work doing. So yeah, he insisted I bring it into the workshop where we stripped the wheel down and cleaned and regreased the freehub and it seems to have cured the problem. Didn't cost me a penny and as he got me to help him I was able to learn how to service/replace a freehub
Hmmm...I'm sure they will...and pay suitable compensation should the chain going into the spokes cause me to fly into a ditch and lay me off work for a month?! Turns out when we stripped the wheel down that they had also put a spacer in back to front. I really liked the bike shop initially; when they dropped and damaged my new bike, causing me a month's wait for a replacement, I just put it down to one of those things. But since then they've sent me home with a replacement bike that turned out to have a faulty rear mech, then when replacing that took off the spoke protector without asking and put in a spacer incorrectly...I'm not sure I'd buy from them againIt's an absurd bicycle fashionista/weight weenie thing to absolutely hate those disks. Don't ask me why. I've tried to get to the bottom of it on this forum with no luck. They shouldn't have removed it without asking you first, but I guess they knew better than the bicycle's manufacturer! If the chain ever slips off the large rear cog, your spokes will be damaged, possibly beyond repair. Not to worry though, I'm sure your LBS will give you a new wheel free of charge!
