Fab Foodie
- Kirton, Devon.
fossyant said:The tyre compound makes a difference - I've done my fair share of testing tyres over the years - tread makes no difference wet or dry - a softer compound tyre will stick better in the wet or dry, but in the wet you get diesel over the surface, so that can negate any advantage.....
Tread won't help you, nor will slicks if there is 'grease' on the surface. What you'll usually find is that slick tread is on more expensive tyres, that generally roll better, hence grip as well.
I love the Michelin Pro Race 2's - outstanding tyres, the best I've used in a long time, and better than any Race Tubulars I used 10 years ago...grippy and fast, and 23mm's provide enough bump deadening....
I've used slick road tyres for 20 years, what is more important is the compound - like on racing cars, and motor bikes. The dual compound works well these days, I remember when you had to be careful cornering when the contact patch switched - was a bit skittish until full contact was made with the sticky bit.....
This is all you need to know about road-bike tyres...
