mjr
- mostly Norfolk, sometimes Somerset
No problems here. Could be your receiver, but could be local weather.
It is fine here now too. The weather hasn't been doing anything extreme here this evening.No problems here. Could be your receiver, but could be local weather.
That seems possible. They're easy connectors to attach to the cable but also fairly easy to muck up. Turn the box off first (unplug it if it doesn't have a real on-off switch), as there's power to the LNB head running along the cable, which is both an annoying tingle and probably not good for the LNB to spark/short.Hmm - I just went to check the signal cables on the back of the box and the picture broke up a couple of times when I touched the connectors ... could be something a bit iffy going on in there!
I'll leave well alone for now but I have more problems then I will disconnect the connectors and take a good look at them.
I just noticed this. Have they waterproofed the connection into the LNB? Otherwise, water may be collecting in that loop, especially if it's CT cable, not modern WF. See "Which cable?" near the bottom of http://satcure.co.uk/tech/cable.htm for the difference.There is a good loop of cable hanging down under the LNB on the dish so water won't be running along the cable into the LNB. What I can see of the cable looks ok.
I'll take a look later.I just noticed this. Have they waterproofed the connection into the LNB? Otherwise, water may be collecting in that loop, especially if it's CT cable, not modern WF. See "Which cable?" near the bottom of http://satcure.co.uk/tech/cable.htm for the difference.
Don't wiggle the bleedin' things. Unscrew 'em and take a good look: is the core long enough, 3mm sticking out of the plug? Is the screen firmly clamped in the collar? If not, remake the connector. Then, plug it back in and do it up snug. See if that improves matters.The signal came and went again a couple of times earlier this evening. I found that wiggling the connectors made no difference at all.
The signal has been lost for about 30 minutes now. I'll try powering the box down, leaving it for a minute and then rebooting it.
Hmm ... I just did that and the core on each cable looked way too long - 10-12mm. I have trimmed them back to about 1/3 of the length and put the system back together. It is currently working.Unscrew 'em and take a good look: is the core long enough, 3mm sticking out of the plug? Is the screen firmly clamped in the collar? If not, remake the connector. Then, plug it back in and do it up snug. See if that improves matters.
That was my thinking too - they were stupidly long!Odd. More often the problem is too short, but I guess a really long core could hit the stop and prevent the outer getting a good grip. It'll be interesting...
Ok, I've done it ... There were subtle changes needed to some of the instructions listed on that webpage but I worked out how to do it.I have just found THESE INSTRUCTIONS explaining how to set up Ch4 HD as a non-Freesat channel.
I can't do it yet because of the signal problems that I am having, but I am wondering how I would set up the recordings since non-Freesat channels would not appear on the EPG?
My older sister is the only person I know with Virgin Media. Yes, the HD channels do look good ... If only they would actually use the HD channels! They always select the SD versions. They don't bother changing to HD even when I point it out.Virgin Media for us and HD looks great.
