Heltor Chasca
Out-riding the Black Dog
I haven't even got as far as cutting the stays yet...it's getting the blimmin bolts to fit the eyelets that I'm struggling with. I'm convinced I must be doing something idiot. Those little holes just behind the axle at the bottom of the front fork and just above the rear drop out are actually mudguard eyelets, aren't they?!
I recon they are but without a close up I can’t be 100%. Take it real easy when attaching any hardware to the frame or fork. If you strip a boss or eyelet it could be an expensive mistake. Sometimes the paint covers the thread and makes it tricky. Once the bolt removes some paint, it’ll be ok. With your fingers, turn a little bolt COUNTER clockwise and see if it ‘clicks’ and then try clockwise. That way you have less chance of damaging the thread. Offer up the stays before you cut anything.
