stabaliser
thanks for all your advice. i'll post up whatever i go for....
all the best.
all the best.
There's nothing special about that hub. You can fit two sprockets each side of most flip flop track hubs.There once was a hub where you could have up to four ratios. Two sprockets on each side
RedBike said:There's nothing special about that hub. You can fit two sprockets each side of most flip flop track hubs.
http://cgi.ebay.co.uk/Surly-Dingle-...8|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
The trouble is you also have to run 2 chainrings at the front so that when you swap to a larger sprocket at the rear you also swap to a smaller chainring at the front. This means the chain length approximately the same and more importantly the chainline remains correct.
Most people just make do with two sprockets of slightly different ratios either side of a flip flop hub. One fixed the other freewheel.
Absolutely. Tho' you can find a better selection on ebay, and if you're smart and patient you can get yourself a bargain. This, eg, will probably go for not a lot, and it is a seriously sweet bit of kit. I know because I used to have one. I only let it go because it was too small for me, and three friends in succession have raved about it, the latest saying just the other day 'I almost killed myself on that damn bike of yours - I had no idea bikes could go so *fast*!'jimboalee said:A suggestion here is to buy an old used bike out of the local rag, strip it down and install a SS.
Then if you find you don't like it, you can reassemble and put it back in the local rag.
