Mark_Robson
- West Boldon Tyne & Wear
In that case I would recommend regular breaks. preferably with a cup of tea.
Mark_Robson said:If you use your laptop to type with you should really have the keyboard flat, as trying to type with the wrists bent upwards can lead to RSI's and Carpal Tunnel Syndrome.
bigjim said:... Don't see many of the great apes walking around with a ramrod straight back and they seem to remain strong and supple into old age.
So like I said not ramrod straight. And why I am more comfortable bent over on my racing cycle/motorbike rather than with bikes that make you assume the more upright position.as happens when you're bent over as on a bike
bigjim said:So like I said not ramrod straight. And why I am more comfortable bent over on my racing cycle/motorbike rather than with bikes that make you assume the more upright position.![]()
Thanks for the info. Consultant thinks my pain is sciatic, had all the scans etc. Started in the knee, lower leg. Nothing found apart from some cartilige damage. I find the bike to be pain free probably because it is not weight bearing. My core and abs are good as I do a fair amount of gym work including plenty of 60K plus squats. Although the knees do complain sometimes if I pile too muchweight on.If you get back pain while standing/walking etc. you ought to get it checked out - it sounds like you've maybe got weak core muscles and tight hamstrings which cause the back to 'flatten' (i.e. pelvis to be rotated back) or just weak abdominals which allow the pelvis to rotate forwards causing too much curve in the lumbar spine - either way gives problems and needs sorting.
monet said:I've recently been suffering with nasty neck/ shoulder pain. This coincided with fitting new handlebars (which initially seemed much more comfortable). After playing with position and taking many measurements I was really struggling to resolve the problem. In the end it turned out that the levers were not quite level (the right was 4mm higher than the left). I'm hoping that's the end of it now!
