shorts in winter - will i damage my knees?
MarkF
Yorkshire
And they don't run about as fast as you cycle.
This is the biggest difference in my view, wind chill.
Wind chill, fair enough. Not that I suffer from that unless going downhill early on a ride! ^_^
I'd never have worn them in a football match and never thought about them for cycling, I do use layers and gloves though. I heat up quick & most are jettisoned after 10/20 minutes.
Keith Oates
Janner
Penarth, Wales
I once read that we should cover our knees when cycling if the temperature is 10 Deg. C or less. I don't know who said this but I generally stick with that suggestion as it's fairly good information and like many things, we can get away with it when we are younger but it might catch up with you when you get older.!!!!!!!!!!!!!
I am rather perplexed with why the fact that someone earns millions of pounds has anything to do with how the cold affects them.
Citius
I suspect we are rather perplexed because we don't understand what you are talking about?
Then you're dafter than you sound, as you you quoted the post only a page back. ;)
Citius
You mentioned their earnings though - I'm struggling with the relevance of that. Unless you can explain ?
Hip Priest
Footballers don't wear overshoes either. What conclusions are we to draw from this? I suspect it's that cold temperatures affect people running around a pitch less than they affect someone whose feet and legs are in being propelled through the air at reasonably high speeds for long periods.
Kajjal
Wheely World
Very different forms of exercise. Cycling for a few hours for most cyclists is easy enough. Continually playing football for a few hours would finish most off.
Citius
Nah, not really...
