I wish I could try, I would definitely if there is an option. The bike I'm buying is online unfortunately, as not much choices available at local bike shopsSo @kingspirit you haven't tried the bike but you are already thinking that it will have too much reach ?
Ride it and try it
So you are spending £???? On a bike you have not tried or even sat on !!!!I wish I could try, I would definitely if there is an option. The bike I'm buying is online unfortunately, as not much choices available at local bike shops
Well the choice in local bike shops this days is limited. You can buy online and in case the size isn't right you can always send it back (some shops organise the courier collection). This is what I did with Fuji Jari, received, assembled, felt that the size isnt right. Sent it backSo you are spending £???? On a bike you have not tried or even sat on !!!!
So once you get it you can ride it and try it then decide.
Crazy times
Magic tool ! Thanks!Shortening a stem can change other things, like the height of the bars.
This website is very good for working out the results.
http://yojimg.net/bike/web_tools/stem.php
Personally, I’d ensure that the saddle is in the right place first then adjust reach by fitting an appropriate stem. I set the saddle by sitting on the bike and spinning the cranks a number of times. I then drop a plumb line over the front of my knee and it should dissect the pedal axle.
Remember that changing the stem length will have an impact on the handling of the bike but this should be minimal unless you are going to extremes.
It’s a drop bar bike…wouldn’t his legs keep hitting the drops?
I have a 50 or 60mm stem on my roadbike.It’s a drop bar bike…wouldn’t his legs keep hitting the drops?
I'm sure, but the bike in the photo has pretty much no stem at allI have a 50 or 60mm stem on my roadbike.
You can and do in some circumstances but it's a bit like toe overlap, you quickly adapt.
