aJohnson
- Bury, Manchester
Nevermind I've got it, it is alot easier with your legs.
aJohnson said:I keep going towards the minus with the allan key but I still don't seem to have a big enough gap for the cleats to go into.
TechMech said:You do realise that the + and - screw has nothing to do with increasing the gap. When you clip the front end of the cleat into the pedal and press down, the back moves backwards under sprung tension and then snaps forward to clip the shoe in. The + and - adjust the tension on this spring from strong to weak, to allow you to adjust the force it takes to clip in and clip out.
Hope this helps
aJohnson said:Yeah now I realize that, I though it had to do with opening the gap, I'm such a numpty.
Downward said:I must be the only bloke who reads instruction manuals !
Garz said:I thought skim reading you took in the important information?
