Shimano XT Rear Derailleur
jethro10
My wifes bike is shimano gearing.
The rear mech is not in good health and she wants me to replace it with an XT one.
Apart from a confusing array of numbers, there seems to be normal and shadow.
Anyone any real world experience of the differences and how to choose on or the other?
thanks
Jeff
gwhite
The "Shadow" as I remember is the model whereby the return spring tension is in the direction of the largest sprocket i.e. opposite to the normal XT. Good for MTB riders I understand. I'd stick with the normal one myself.
I like Skol
A Minging Manc...
As far as I know the 'Shadow' part just means it is the newer design mech which is lower profile (doesn't stick out as far) and has different cable routing (again, is less likely to snag on anything as it enters the mech from above rather than the rear, eliminating the big loop of cable at the rear)
In 2009 I fitted THIS SHADOW MECH to replace my 1994 traditional style XT rear mech and it has worked fine although I wasn't certain it would work when I ordered it.
It is not reverse sprung so was a straight swap after a bit of cable shortening.
RecordAceFromNew
Swinging Member
West London
As Skol said I believe XT shadow only comes in top normal currently. Both are XT but the one on the right is Shadow:
e-rider
Banned member
South West
wrong - shadow means a more low profile design where the cage protrudes less
I always avoid the shadow options as it seems like a bit of marketing crap to me. M771 is the XT model to go for IMO however the normal Deore M591 is a good cheap(er) option.
GrumpyGregry
Here for rides.
XT looks nice as it has XT written on it. XTR looks nicer still because as we all know that go-faster R makes all the difference. Deore works just as well and is cheaper.
RecordAceFromNew
Swinging Member
West London
The R on my M971 is relieved - if they had taken it off they would surely have saved a gram or two instead of weighing and slowing me bike down? No I checked those lazy bones did not hollow out the back!
gwhite
Ah well, there you go. Of all the reasons to introduce a new model. Who can fathom Shimano's marketing?
02GF74
ahh.... I wondered what the shadow bit meant.
the "rapid rise" has the derailleur moving in opposite direction i.e. when the cable is pulled, the gears go down - IIRC was made as seemingly the downhillers needed to shift faster and more positively to the smaller cogs.
marvin
Bristol
I had a bit of an accident on the ice recently and my rear derailleur has cracked. I plan to pick up a new one online and replace it myself. How hard a job is it? I like the idea of doing it myself but hate the idea of going to my lbs asking them to fix my bodge job.
