- South Manchester
You probably won't need to dismantle it. Check the calliper moves OK, check the cable, then drown it in GT85 (pads removed) and clean it up.
I have a pair of tiagra brakes that the lever that you move to open the brake up doesnt do anything anymore .
I think mine's getting like that - the amount of movement is negligible.
Needs a good clean then. I'm running 35 year old Shimano brakes that still work fine - just a case of regular cleaning and some lube. I've always centred mine, including dual pivots, by using a cone spanner, rather than the adjuster screw. It's more reliable.
im on about the lever that opens the brake to allow the wheel out, the calipers are super clean and lubed but the lever doesnt do anything at all .
One block was more hard on the rim than the other.
As for the caliper, with some finger pressure it will swivel a bit to allow me to even out the gap between the pads/rim.
Does the fact that it will swivel a bit, mean that it needs tightening more? I tightened the hex bolt round the back last night, but the caliper will move when you put manual pressure on it.
