DCBassman
- The lumpy far South West
Maybe... Never say never!Indeed. Unless it was a US only thing. Which would be even weirder.
Like I said, odd. Nothing in any documentation I can find...But there it is!ST-3300-7
That's an 8-speed sprocket.
How do you know this, please?As for the OP, he has an 8-speed system,
I must improve my standard of observation.Quite clearly 8 sprockets.
You have 8 sprockets on the cassette in the image you shared (I presume from the bike in question).I'm not really sure what that means as I have 7 gears in back and 3 in the front.
OK, let's pretend I don't know a lot about bikes (yet!) . . . I'm not sure how to count the clicks. While riding the bike, start out with the chain on the largest rear gear and count the clicks as the chain moves down to the smallest (lowest) gear? Or? Since there's 8 gears on the rear that should be 7 clicks right? Another thing that's confusing me; since my Cannondale has 8 rear gears do I refer to it as an 8 speed bike? What about the front 3 gears? Thank you for indulging me. :-)No - as I said in a previous post, Sora is now 9 speed, and you definitely haven't got that.
How many clicks on your RH shifter please?
You are correct about how to count the clicks, move all the way to one end and then count how many clicks to the other end, as you say, there should be seven clicks in an eight speed shifter.OK, let's pretend I don't know a lot about bikes (yet!) . . . I'm not sure how to count the clicks. While riding the bike, start out with the chain on the largest rear gear and count the clicks as the chain moves down to the smallest (lowest) gear? Or? Since there's 8 gears on the rear that should be 7 clicks right? Another thing that's confusing me; since my Cannondale has 8 rear gears do I refer to it as an 8 speed bike? What about the front 3 gears? Thank you for indulging me. :-)
Thank you!That's confirmed it's an 8 speed drivetrain (STI and cassette). The LH STI is broken and merits replacing (you need a 'triple). The RH STI is fine, so only replace it if you have a 'must match' issue.
For a set you need Shimano Claris (8 speed) and you'll likely get them second hand and hardly used (surplus after an 'upgrade').
You can pay £90 for them new. ST-2303 have the thumb levers for shifting down. ST-2400 have the inner and brake lever style.
Just replacing the LH STI you can find old (triple) Sora or old (triple) Tiagra: they all shift the triple front derailleur the same (with clicks for trim) - just make sure the one you find is 'triple capable': some aren't.
