itboffin
- Marlborough, Windshire
doesnt it just beed bleeding? even my mechanical STI disc brakes engage like your first pic
That's not right. I suspect better bleeding required.There should be no hydraulic challenges!As with a car or motorcycle...or MTB they should just work!!Unfortunately my first experience with Road-hydros is proving otherwise!
OK here's where I want them and expect them to engage:-
Here's where they actually engage:-
Not acceptable and not what my experience of hydraulic brakes is or has been.Absolutely zero modulation or progressive feel.
I have Di2 on one bike and RS-805 on another, I cannot pull to the bars on either. For sure, the biting point is not as keen as on my Shimano equipped MTB, but yours does not right. If you pump them a few times do they firm up?There should be no hydraulic challenges!As with a car or motorcycle...or MTB they should just work!!Unfortunately my first experience with Road-hydros is proving otherwise!
No difference with pumping.I've tried strapping the levers over night and that makes no difference either.I have Di2 on one bike and RS-805 on another, I cannot pull to the bars on either. For sure, the biting point is not as keen as on my Shimano equipped MTB, but yours does not right. If you pump them a few times do they firm up?
Waste of time and money. You might strike lucky and get them to bleed that way but it will be nothing to do with the new parts. How are you bleeding them, top to bottom or bottom up? I had an mtb brake that gave me a bit of trouble about a year ago after replacing a damaged hose. Bled it multiple times but results were an inconsistent bite point that also seemed to vary during usage. I became convinced that somehow air was getting in & out of the system at the master cylinder (hence the inconsistency) so decided the solution would be to reverse bleed via the caliper nipple and force any air at the lever out via the reservoir.I think I'm going to start again.New hoses/barbs/olives and fluid.It'songt but you never know.
I always fill bottom up with a syringe in the caliper bleed point on shimano road systems, but I use Hope RX4 calipers. Once I've got it filled I pump the pistons out and push them back in a few times then lock the lever against the bars and put a really good vacuum on the caliper by pulling the syringe plunger until the bubbles stop then pushing fluid back in. Once I've done this a few times and can't get any more bubbles to appear I make sure the reservoir at the top is full by pushing fluid up from the syringe until it almost overflows (I never put fluid in at the top), then put the reservoir cap back on. Then make sure pistons are all back in and take the syringe off the caliper and reinstall the bleed screw. I don't know what the 'correct' procedure is, but this is what I've developed over the last few years and seems to work for me 😊
I’m going to try that. Thats how Car,motorbike and Hope brakes are bled.Have you tried pumping them and then opening the nipple? This might shift that last bubble of air that is causing the bite point issue.
You can use hope calipers with Shimano levers...I’m going to try that. Thats how Car,motorbike and Hope brakes are bled.
If only Hope made Di2 compatible Brakes/STIs
It looks like my build is not quite finishedHope RX4-sh calipers, thats what i have on my two Di2 road bikes
