rapid rise rear mech not been shifting properly for a bit, then on a rocky descent at the bottom i find the top jockey wheel has fallen off. Thought the two could be related. So get a new one.
Still not shifting right. Set it up completely correctly, including setting the b-tension screw (have to back it right off as i run a 12-28), setting limit screws, then setting cable tension. But when the cable is taut enough to switch from 1 to 2, it's not slack enough to switch from 9 to 8. Slack enough to switch from 9 to 8, and it needs two index positions to switch from 1 to 2.
So put a sram one on and new sram shifter, shifts absolutely perfectly first time without even any cable tension adjustment. Shifts into each gear promptly when the shifter is in the index position for that gear.
The sram mech feels chunkier and better made. Even in detail, like the limit screws are bigger, the b tension adjuster is an actual allen key bolt rather than a screw, and the cage just feels stronger and better quality.
I'm thinking the shitmano shifter must have had it, as every other possible reason for the crap shifting has been eliminated - can't be that i'm setting it up wrong, as the sram setup works absolutely fine first time. Can't be the new mech as it's brand new. Can't be the cables as they're new(ish). so by process of elimination the shifter must have in some way had it.
my scott is now my only bike with shimano gears, and that has got a new rear mech after the old one SNAPPED clean off right through the body at the point where the limit screws go in.
these two pieces of misfortune are leading me to the general opinion that shimano gears are shite ...
