deathtokoalas
Member
my grandmother gave me this italian-built bicycle years ago, because it was just sitting in her apartment storage. i'm going to guess it's a 90s model, or earlier, but it was like a brand new bike when i got in 2011. i have ridden it to the brink the last few years and now have what i believe is labeled a "loose crank arm".
i bought a ratchet set to try to fix it, but i can't unloosen it, which is leading me to the conclusion that it isn't loose. i'm a thin/toned type (i have no upper body strength), but i'd imagine i could get the thing loosened if that was actually the problem, because it would be...loose....
i can't find any information about the model online, and what i'm learning from watching youtube videos is that the system is rare nowadays, but what i'm wondering is if the actual problem is not that the crank is loose but that the lock ring and cone, together, just somehow just fell off, or were perhaps vandalized. i'm also wondering if there isn't actually a bolt on the bracket at all.
i have some pictures:
does that look like parts are missing in the shaft? is it just the ring? the cone? both? more?
if just the ring falls off, is it typically loose? is it required to actually fix, or is it just annoying?
in a scenario like that, it may potentially be an inexpensive fix, if i just need to replace the $5.00 parts around the bracket, but if i understand correctly, i'd have to take both pedals off to do it, and that requires buying specialized tools. i didn't mind buying a ratchet set because i should have a ratchet set, anyways, and i thought i had no choice but to disassemble it. if it's actually too tight to take apart, i might not want to at all. how often are fixes like this actually successful?
it's a nice bike, in theory, but it's been ridden to death, and i'm trying to determine if trying to fix it is actually worth it. my budget is very small (i would replace it with a used bicycle that will certainly have a much shorter lifespan than this one). i will no doubt fix it eventually. i mean, i'm not going to landfill it.
j
j
