Tenorman
- Newark-on-Trent
Hi everyone
Bit of a newbie question for my first post. I picked up a Raleigh Pulsar from eBay last year, with the intention of using it as a bit of a project bike. I've put on new wheels, rear cassette, rear derailleur, and all the things I've been able to do before. I bought some Shimano Sora dual pivot brakes to replace the old side pull calipers on it. The basic problem I have is currently fitting the rear brake. The brake bridge (if that's the proper word) has the usual hole where you can attach parts of the rear rack, mudguards, and a caliper brake. The old brakes simply have very long bolts to go through the bridge, and then a nut to secure the rear. The Shimano brakes have a much shorter bolt and a sleeve-type nut to recess into the hole. Unfortunately the hole is too small and the sleeve won't fit inside the hole. I've very little (read none!) experience with doing anything to frames. Is it reasonable to either use a drill or a metal file just to enlarge the hole to fit the brakes, or would this be causing some problems for the future?
Thanks for reading such a ramble!
Colin
Colin
