Mo1959
- Perthshire,Scotland
Hmmm, think my 2018 Specialized Ruby might have this crankset. For all the times I am actually riding these days, I might just hope it's ok.
The bike shops are really just doing a visual inspection looking for any cracks which to be honest you can do yourself . Any clicking or creaking from the chain set is the first sign of failure so just keep an ear out for that . The source of the problem apppears to be galvanic corrosion caused by a chemical reaction between the different metals and salt and water so if you've ridden in the dry mainly it unlikely you will get an issueHmmm, think my 2018 Specialized Ruby might have this crankset. For all the times I am actually riding these days, I might just hope it's ok.
That's the price you pay for progress.The quest for ever lighter kit eh. The biggest issue (for me) is the proprietry chain rings that are needed. Three of my bikes use standard 5 arm 130 or 110 BCD patern, you can get any chain rings. Two don't - one uses a slightly unsual BCD but I can get aftermarket rings, and the other set is SRAM and it's only their rings I can get, at cost (I do ebay searches to pick up spares before I need new rings).
That's the price you pay for progress.![]()
Thousands of cases, yet denial of a design problem.Shimano denies design problem with Hollowtech cranks despite reports of cracked arms
That bike's weight reducement, as said above, I consider that futile.Hollow forged crank arms A lightweight crankset not only reduces the bike's weight, but decreases rotating mass to aid in acceleration. The challenge is to reduce the weight of the crank without reducing its strength and rigidity. SHIMANO's advanced forging technology has solved the problem through the HOLLOWTECH crank.
Just some thoughts...
https://road.cc/content/tech-news/shimano-claims-no-design-problem-hollowtech-cranks-287827
But what are alternative explanations? Too many people with too much leg power due to a mutation in their bio?
All those people where hit by a car on that crank?
In science they say that the observation overrules the theory.
It's clear that Shimano just attempted to manoevre out the reputation and with it, sales blast.
That long. Until the attempt itself already did that, and further denial would just make it worser.
Why did Shimano started to make cranks hollow?
To save on weight, is a given explanation.
But the cranks of a bike, are a small fraction of the weight of a bike.
So unless for racing people, competition, the gain is not worth the hassle/the specific vulnerabilities of aluminium.
I think that the real reason is just cutting cost. Alu is much easier>cheaper to machine than steel.
In such a degree that, instead of just massive material, even "constructing" a crank from parts, still cuts the cost more, with the weight saving argument used as excuse-explanation.
A crank is a bike part that undergoes alot leveraged force (strength) and alot force fluctuations (stress>fatigue), causing the mounting positions to be critical.
Look at the picture of the broken spider crank, it's clear that the first break was the one near the pedal eye "insert" of whatever that is named, the 2 crank U shaped parts separated, thereby wiping out the strength that construction adds, usually meaning a total erasing of strength in at least 1 direction, the outwards U then broke off near the spider, and garbage the entire crankset and with bad luck, and with this part of a bike, it doesn't have to be *that* bad luck, garbage is your head too.
Add to that design a vulnerability to a variety of kinds of corrosion, and you have a recipe for sudden disaster, and that's what was "observed", that Shimano kept denying probably until their lawyers told them that an admit and recall would end cheaper.
This is an advertisement extract:
That decreasing rotating mass in acceleration is blah, the mass of a crank is spreaded over its length, and at the outer end there is a pedal, about 200-400 gr, what's a hollowtech crank? <100 grammes? And a shoe, and a foot, ... ? Then tell me how inertia would make any difference worth the hassle?
Not that Shimano deserves a special blame here, alot stuff these days is made like that for that same reason of cost cutting. Selling crap with a quality + quality control mark and spare parts included is default practice.
The product ends in a garbage bin without any spare part used because the typical wear parts last longer than the body. :P
I think their actions are driven by a combination of both lightweight and cost - let's not forget that typically in recent years 105 has been functionally very, very close to Dura-Ace; the big difference being the latter's reduced mass to justify the fact it costs what, 2.5-3 times as much...?Just some thoughts...
Certainly share that perspective with placcy cranks; while I don't much like the fat aesthetic of the box-section road cranks either (nor the snappy-snappy of course!).Hence why I don't have any hollow cranks. You don't see that on Shimano MTB cranks. I'm not keen on carbon cranks either.
Cranks have been made of aluminium (not steel) for many years (spindle is steel) it's an ideal material for cranks. The displayed failures are caused by glueing challenged by galvanic corrosion resulting from steel (spindle) and aluminium box section crank/spider.So unless for racing people, competition, the gain is not worth the hassle/the specific vulnerabilities of aluminium.
