youngoldbloke
- but .... Tiagra is 44xx, 45xx, 46xx etc, Sora is 4300 etc, and Claris is 2400 etc ... don't think Shimano are too worriedThe number 4 is considered unlucky in the far east.
- but .... Tiagra is 4500, Sora is 4300, and Claris is 2400 ... don't think Shimano are too worried.
OopsSurely Sora is 3XXX?
It means Shimano are less superstitious than segments of their customers.- but .... Tiagra is 44xx, 45xx, 46xx etc, Sora is 4300 etc, and Claris is 2400 etc ... don't think Shimano are too worried.
Like the new levers but the name is pants .
You can get sora rear mech for less than £20 , got mine from ribble and its been great so far.Replaced the old 2300 mechs that i had worn out 2 of in the last 3 years.I'm in the market for a new rear mech, can you buy them yet?
I need it for an 8 speed triple setup and I was told by Wiggle when I contacted them that the Sora 3500 was 9 speed specific and an 8 speed chain wouldn't run smoothly through the slightly narrower cage. What setup do you use yours on?You can get sora rear mech for less than £20 , got mine from ribble and its been great so far.Replaced the old 2300 mechs that i had worn out 2 of in the last 3 years.
9 speed mech with an 8 speed chain and cassette, works fine for meI need it for an 8 speed triple setup and I was told by Wiggle when I contacted them that the Sora 3500 was 9 speed specific and an 8 speed chain wouldn't run smoothly through the slightly narrower cage. What setup do you use yours on?
Ok thanks for the advise I'll probably try the Sora then, doesn't hurt that it's about £40 cheaper than the Ultegra either9 speed mech with an 8 speed chain and cassette, works fine for me
