migrantwing
The stamping on my chain reads: 'HG' 'CN 5701' 'VIA'. It also has stamped on it 'IL'. Can anyone tell me what the 'IL' stands for? Just curious.
TIA
TIA
I bet it denotes inner link, also see this. If I were you I would get kmc or sram when it is time to replace.
Thanks for the info. Why do you suggest a KMC or SRAM chain when it's time for replacement?
Surely that would have been covered under warranty?You don't have to use the pin to join a Shimano chain, just as you don't have to use (the even more annoying) Campag system to join their chains. Just use the appropriate KMC link. However, I can't enthuse over KMC chains as I had to replace one of their most expensive X10SL after only 120 miles or so, when I discovered one of the side plates coming loose from a pin.
+1, unless of course if the chain had been mangled between frame/cog by it coming off through poor indexing etc. Inevitably, a price of going 9, 10, 11, 12 speed...Surely that would have been covered under warranty?
derailleurs is increasingly flimsy chains.+1, unless of course if the chain had been mangled between frame/cog by it coming off through poor indexing etc. Inevitably, a price of going 9, 10, 11, 12 speed...derailleurs is increasingly flimsy chains.
Depends on the speed of your chain, 10 or 11 speed, I definitely reccomend KMC because their links are reusable, SRAM are not; if its 9sp or less I'd just go for what ever is cheapest (SRAM or KMC) both seem to be good quality chains and both have reusable quicklinksThanks for the info. Why do you suggest a KMC or SRAM chain when it's time for replacement?
