Hi there, does anyone know if this will fit my 2009 GT Avalanche 3.0. Many thanks
seed New Member 1 Apr 2021 #1 Hi there, does anyone know if this will fit my 2009 GT Avalanche 3.0. Many thanks Attachments Screenshot_20210401_185840_org.mozilla.firefox.jpg 45.2 KB · Views: 5
Drago Legendary Member Location Suburban Poshshire 2 Apr 2021 #2 How many speeds does your bike have, and what make are the shifters? If the answers are a) 7, 8 or 9, and b) Shimano, then yes.
C R Guru Location Worcester 3 Apr 2021 #3 Drago said: How many speeds does your bike have, and what make are the shifters? If the answers are a) 7, 8 or 9, and b) Shimano, then yes. Click to expand... Should also check that the mounting is correct, it may need a claw mount. Photos would help.
OP OP seed New Member 3 Apr 2021 #4 Thank you Drago, the bike has 8 speed and it has shimano shifters. Both the derailleur and the shifters are stamped Shimano Alivio.
C R Guru Location Worcester 3 Apr 2021 #5 I just realised that the image you put is for a 9 speed, not sure if the pull will be correct for an 8 speed.
C R Guru Location Worcester 3 Apr 2021 #6 Just checked, 8 and 9 speed pull ratios are the same, so that one should work for you.
