Fattman
- Roydon, Essex
To follow up... have just checked Zinn... he has a very long section on chainline and the problems it can cause with dropping off and chain rub. He blames it largely on an incorrect bottom bracket width setting the chainrings out (not likely as a problem if running with a Hollowtech BB) - though it could be frame misalignment. I guess it might happen if the sprockets are off - e.g. if missing (or excessive) shims?
Anyways, to check apparently either (a) simply put a long rigid straightedge between the chainrings and see where it lines up at the back or (
complicatedly measure loads of stuff like wot he shows in his pictures in Zinn and the Art of Road Bike Maintenance.
