roubaixtuesday
self serving virtue signaller
Agree, but I stupidly bought a pressfit 86 frame so can't fit a triple. I would otherwise have fitted a triple in a heartbeat.
Clearly it's time for a new bike
It will work fine with 11-36 if you have medium cage not short cage. However I do not recommend the cheap cassette and the goat link. I tried the cheap cassette and shifting was crap. When you look closely, it doesn't have the hyperglide sculpting and makes it horrible to use. Also goat link compromises shifting performance. The only reason it may be necessary is to clear the gap between the largest cog and the guide pulley. You don't have that problem with 36t, you'll be ablr to clear it just by using b screw. Therefore do not use goat link and use Sram 11-36 cassette.
Also why not just use 50-34 unless you absolutely need 52-11 which you don't. I think I spun out at 45 mph with 46-11 going downhill. Do you regularly go over 50mph on flat?
I agree. I am not interested in speed on flat. I hardly go over 15mph on flat.
I thought changing the cassette is easier and less expensive than changing the front to 50-34.
both pretty easy jobs to be honest, if you buy and sell lightly used changing chain-set might actually be cheaper.
what you do get with changing front is a regular set up, that will change more slickly, rather than a dodgy back end with wolf teeth etc.
For a couple of thousand miles now I've actually been using one of the 'cheap' Airbike cassettes that the OP has bought and it shifts just as well as the previous Ultegra/105 cassettes that I've used in the past, I really can't tell any difference. Time will tell if it wears OK but if it does I'll be going back for another! For info mine is an 11-34T paired with a medium cage Ultegra rear mech and SRAM PC1110 chain.
I think shifting quality on that cassette varies depending on the RD you've got. I heard that older generation Shimano RDs are more tolerant of these non-hyperglide cassettes. Newer "shadow" style RDs apparently suffer more. If you watch videos by tracevelo on YouTube, he's done a lot of testing with Chinese cassettes. My personal experience was that Shimano cassettes are noticeably superior.
Which chainset have you got? You can experiment with the cheap cassette which is still 30-40 quid. If you get the Sram one it's like 70 quid. So replacement chainrings (not the whole chainset) might be cheaper.
52-36.
I may get away with changing the 36 to 34?
I think you'll get away with changing to 34. People have done similar with no problems.
I don't mean to disparage affordable Chinese made parts by the way. I use them wherever I can. I literally just meant that the cassette is cheaper than Shimano or Sram ones.
Same applies with change of the front ring?
