Setting Up New Bike
Eucid
Hereford
Hello,
I'm new to cycling, but I come from athletics, where I competed internationally.
Below are a couple of photos with angles on them of a rough set up. Just wondering if anyone could shed any info on them.
0vby8mj
mznha3p
I will be getting SPDs in the next month or so, will probably need to slightly change the set up when I have them.
Thanks
PaulSecteur
No longer a Specialized fanboy
Hi,
I cant see you pictures, it looks like there is something wrong with the image tags. I see the black box with the cross in it, then
Eucid
Eucid
Hereford
Me too. If I right click I can "Open Image in New Tab". I followed what is says to for uploading picture, don't know what happened...
Cyclist33
Warrington
Hello,
Not sure what the relevance of this revelation is!
0vby8mj
mznha3p
Not sure what you're asking for info on! I think fit is personal and will depend on what's comfortable for you for how you want to ride. We don't have all your vital statistics (and I don't want them!) so just start with a neutral setup from the bike shop and tune your angles bit by bit till you get where you want.
Don't see why this in itself would necessitate a setup change!
Thanks
cyberknight
You might need to raise the saddle slightly to account for the slight increase in pedal/cleat thickness, i can tell if my saddle is out by a couple of mm .
Is your set up comfy for you atm ?
slowmotion
Quite dreadful
lost somewhere
nickbuxins
fGm5
