ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
Each cleat uses 2 of the 4 holes.Once they are in place, do they fix in the 4 recessed black holes or do I fix these in position prior to attaching the cleats?
Ah, @Landsurfer has got in there ahead of me while I was typing...
You choose the forward or backward pair of holes according to which give you the better cleat position, which is up to you to decide.
I don't agree with the advice not to initially 'excessively' tighten the bolts... I did that once and the cleat just turned when I tried to unclip, so I couldn't unclip. I had to take my foot out of the shoe and faff about to get it off the pedal. I set the cleat position, then tighten the bolts. I do agree about going for a test ride and seeing how the setup feels. You don't want any sensation that your feet are unable to go freely to the angle that you want them to be at. I like to ride 'heels-in' so I adjust the cleats so that my feet go naturally to that position without the cleats resisting the movement. You also need to make sure that you can unclip without an excessive rotation of the feet. If you have the cleat too far one way, you would struggle to unclip. Too far the other way and you would accidentally unclip. It isn't hard to do all of this. If you don't get it right first time (you probably won't!), loosen the bolts and make a slight adjustment.
In case it isn't obvious, the cleats need to be rotated in the opposite direction to the way you want you foot to move! I.e. if your heels are too far IN then the backs of the cleats need to be adjusted to be further OUT.
