Sense check on brake pad purchase
Twizit
CS8 lead out specialist
Surrey
About to purchase some new pads for my bike (Spesh Secteur) and having one of those silly moments of doubt - have never bought replacement calliper pads before
Koolstops salmons seem to be the way to go, so would these be the right ones?!
Koolstop Supra 2
However Sheldon B seems to indicate the MTB branded Koolstops are the best and can be used on any type of brake, so could I go with these instead???? i.e these:
Koolstop MTB / BMX pads
Many thanks and apologies for thicko questions
Angelfishsolo
A Velocipedian
I might be wrong here but I think that the pad shape is wheel diameter dependant. You may end up with two much or not enough of a curve on the pads.
Koolstop Supra 2
BSRU
A Human Being
Swindon
Koolstop Supra 2
There certainly not thicko questions, especially when it involves safety and spending some hard earned cash.
I use MTB salmon Koolstops on my hybrid with 700c wheels, I also read Sheldon's advice and I have had no problems.
The second set you stated are for BMX's.
PaulSecteur
No longer a Specialized fanboy
NOOOO!!!
Those are both wrong! They are for cantilever or V-brakes.
I dont have time to get a link to the right ones, but thems is definatly the wrong `uns!
EDIT: They should look more like this...
http://www.dotbike.com/p/5993
Once you have the right brake pad holders you can replace just the pads from then on, usually about £8 a pair.
Kestevan
Last of the Summer Winos
Holmfirth.
The Supra 2 pads can be used in cantilever brakes which dont have the removable/replaceable cartridge pads. I think the low end Shimano brakes (sora and below) come fitted with this type of 1 piece pad where the bolt is moulded directly into the pad.
Assuming this is whats on the OP's bike They should fit, and will probably be a vast improvent over the original crappy Shimano pads.
However..... if it was me, I'd take the opportunity to dump the single piece pads, and move up to the replaceable pads and holders like the ones above ( http://www.dotbike.com/p/5993 ). They offer more flexibility and cheaper pads. The cartridge holders should be a direct replacement for the one-peice jobbies.
Twizit
Twizit
Surrey
Cheers all
Kestevan, I'm on an entry level Secteur with completely unbranded brakes, so you're right in that they currently have one piece blocks which are fairly chocolate fireguard like in their usefulness.
Will have a look into the replacement cartridge type.
Ta
PaulSecteur
Please note that the link I posted isn't a recommendation for (or against) dobike, I have not used them. They were the first ones I found with a picture.
Twizit
Twizit
Surrey
Thanks Paul - and don't worry - managed to find them a little cheaper elsewhere anyway - will report back how I get on!
.... hopefully improved braking performance.....
Brandane
Costa Clyde
Hoping for the same improvement in braking performance; coincidentally also on a Secteur. The original one piece pads are pretty useless and also give the impression that they are grinding the rim away with every pull of the brake lever. I have Koolstops on my Tricross and what a difference they make!
I found the Koolstop RE460s a couple of days ago on dotbike and ordered 2 pairs. Couldn't find them ANYWHERE else. Usual suspects like Evans, Wiggle and ChainReaction don't seem to stock them. Even Google was no help, so was just wondering where you found them cheaper Twizit :thumbsup:.
Twizit
Twizit
Surrey
UKBikeStore - haven't used them before but seemed to get ok reviews, so here's hoping...!
Will let you know if they actually turn up....
rossjevans
Bournemouth
Is it the RE460's which you use on your Tricross?
