JamesM
- West Yorks
I would make the following recommendations to anyone with, or looking to get a bike to help you keep it!
I hadn't made a note of the serial number so there is no real chance of it being identified as ours even if the thief walked up to the police station and handed it in (unless they gave our address too which is even less likely!)
Anybody with further advice, please add it below. I know a lot of this advice is available elsewhere on the forums. Just thought it might be useful to people in here.
*While this won't help you keep your bike, it will help the police to identify stolen bikes and thus bike thieves.
- Take a note of any serial numbers and consider getting your bike marked with your postcode (I believe you can do it with a UV pen. The serial number is usually on the frame under the pedals)*
- Lock bikes when they're in sheds etc (Preferably to a ground anchor)
- Make sure sheds etc are as secure as possible (If a padlock's as good as you can do, make sure it's a good one and the fittings are securely attached with a plate at the other side, not just screwed into soft wood)
- Try to keep valuables out of sight (e.g. Whitewash or otherwise cover windows if possible)
- Check your bike is covered on your insurance, particularly noting any requirements on storage. Check the maximum value covered and the excess too.
