Hi All first Thread be easy🙏. I have a carrera Titan mtb that needs a new seat the post is still there but have no fittings for seat, Can I get the seat with the fittings or is this separate.
Thanks Chris
is it this one ?
https://www.halfords.com/bikes/mountain-bikes/carrera-titan-mens-full-suspension-mountain-bike---s-m-l-frames-green/grey-850633.html
if so you should be able to pull the old post out to check the seatpost size to buy a new one , its normally stamped on the post
in this case 31.6 according to the blurb
This is the stem post that belongs to bike, as you can see its seen better days and looks like it was cut dwn in length, the seat has rails on it.
In case not clear @ICF67 there basically two types of post: one simple type onto which you can slide and secure the fitting to which @Paulus has linked, or (more normally for this quality of bike) one which has the fastening for the saddle rails integrated (see the seatpost in @cyberknight 's link.
As said, pull out the current post and its diameter will be marked. You also get different lengths eg 350mm. Be guided by your current one, noting how far above the minimum insertion marking | | | | | you have it positioned for your leg length and riding style.
