Seat Post Marking's
  • Thread starter Deleted member 1258
  • Start date
Deleted member 1258
I've got a new Flyer and on the seat post there's a set of numbers that count down vertically, starts at 10 and goes down, I've got a lot of seat post showing and I'm down to number 8, I presume it goes down to 0, I haven't had the seat post right out. Now is this decorative or is it done to show how close you are to the maximum amount of seat post showing? Its not something I've come across before and an internet search didn't bring any information up.
Vapin' Joe
Formerly known as Smokin Joe
It's so you can reset the post to the correct height if you remove it.
Citius
The marks are largely pointless. If you want to re-set your seatpost after removing it, just wrap a piece of electrical tape round it where it meets the top of the seat collar, before tasking it out of the frame.
Deleted member 1258
On a black seat post I normally use a dab of Tipex, but I can see the numbers being useful for setting the post back to where you had it.
Citius
The numbers - a bit like the tippex - will wear off over time. A bit of electrical tape tends to stay put.
Deleted member 1258
Tipex can be redone easy, but not the numbers, the flaw in the idea, but once its set up I wont disturb it very often.
Pale Rider
The marks are a great idea because it saves having to wrap scabby bits of tape around your seat post to mark its position.
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
As others have said, it's to give you a quick and dirty idea of seat height when changing from riding styles
